2004 Acura MDX a/c and heat
2004 ACURA MDX
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
LI333
I'm not getting any air coming out of the front and rear vents when both the a/c or heat is turned on. I checked the fuses and they seem to be fine. Can you suggest any other solutions?
Sep 30, 2009 at 9:45 PM
KHLOW2008
  • 41,814 POSTS
Hi li333,
Do you mean the blower fan mortor is not working?
Oct 1, 2009 at 3:03 AM
LI333
yes. I'm not getting any air in any of the vents.
Oct 1, 2009 at 6:51 AM
KHLOW2008
  • 41,814 POSTS
Check the blower motor terminals for batttery voltage when ignition switch is turned ON. If voltage is available, test the blower by applying battery voltage and grounding the other terminal. If blower doe not work, it is bad.
Oct 1, 2009 at 7:08 AM
