Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
MDX
Engine
Timing Belt
Replace/Remove
2003 Acura MDX timing belt replacement
2003 ACURA MDX
83,000 MILES • 6 CYL • AWD • AUTOMATIC
JIM R WOODS
MEMBER
1 POST
What is recommended replacement schedule? Should the idler and water pump be repalced at the same time? How many shop hours does this job require?
Jan 4, 2009 at 4:07 AM
ZACKMAN
Experienced Mechanic
You should replace the idler. Water pump does not run off the timing belt, so no.
Feb 22, 2009 at 4:17 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
