2003 Acura MDX Steering pulls
2003 ACURA MDX
MARCH2793
Steering problem
2003 Acura MDX All Wheel Drive 99000 miles
I just purchased a used Acura and noticed when I drive that the steering pulls what do you think that is? Is it normal for an AWD vehicle
Mar 15, 2010 at 4:30 AM
LEGITIMATE007
  • 5,121 POSTS
does this happen when applying the brakes,? or just going 60 on the highway
Mar 15, 2010 at 4:42 AM
MARCH2793
No it pulls at all speeds. Steering also feels stiff
Mar 15, 2010 at 4:45 AM
LEGITIMATE007
  • 5,121 POSTS
ok make sure you have power steering fluid in it, and I think the pull to one side is that you need an alighnment. but you can never be too sure, if you have a warranty get it back there and make them fix it, if not then you still need to get it back there and ask them why its doing that, and the care is supposed to have no problems with it. can they kindly fix the problem
Mar 15, 2010 at 4:51 AM
MARCH2793
I bought it from a private party. If its the rack inpinion going bad what would it feel like.
Mar 15, 2010 at 4:57 AM
LEGITIMATE007
  • 5,121 POSTS
a stiff wheel. but a bad powersteering pump and low fluid will cause this too.
Mar 15, 2010 at 5:05 AM
