2003 Acura MDX Power Steering Problem
2003 ACURA MDX
97,000 MILES • 6 CYL • AWD • AUTOMATIC
JMV9999
When car is stopped, steering is hard. Okay when moving. Mechanic replaced rack and pinion and pump, also added fittings and greased ball joints. Still has problem steering without moving.
Oct 11, 2008 at 10:54 AM
KHLOW2008
  • 41,814 POSTS
Hi jmv9999,
The problem seems to be from the pump. You need to test its pressure. Check for kinked pressure pipe as well.
Oct 26, 2008 at 8:33 PM
