Mixed fluids where? In the transmission? And what kind of fluids?Where you told of what kind of damage? Engine oil is kept in the engine and trans fluid in the trans. They don't meet anywhere, someone had to put it there for them to mix, wether by mistake or not it can only be human error that would cause it. Unless it was coolant found which would indicate a cooling system problem not necessarily meaning engine replacement
acura has an extended warranty on transmissions because it's such a common problem(120,000 miles I
think) try to call the dealer first
could you let me know exactly what they said about the engine?
SPONSORED LINKS
Tuesday, April 15th, 2008 AT 6:46 PM
