2003 Acura MDX CHECK ENGINE LIGHT
2003 ACURA MDX
93,000 MILES • 6 CYL • 4WD • AUTOMATIC
MRP
I know this onboard computer is sophisticated and that it will detect most issues so is it normal if every 9 months a check engine light goes on and there is some new issue?
how many different items does the check engine light address? this current problem is smalll ,evaporator leak, but it is the second check engine light issue in 9 months.
thanks.
Aug 27, 2008 at 7:35 AM
KHLOW2008
  • 41,814 POSTS
Hi mrp,
There are a few hundred possible reasons for the Check light to show and you should get a scan done to find out what is wrong.
Aug 28, 2008 at 2:48 AM
