2002 Acura MDX TCC Circuit Malfunction
2002 ACURA MDX
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
2002ACURA
The check engine light came on, so I hooked up to a code reader and received a code of P0749 TCC Circuit Malfunction. Dealer stated that I would need a new transmission, or can the the torgue converter be replaced.
Aug 16, 2010 at 5:05 AM
KHLOW2008
  • 41,814 POSTS
Hi 2002acura,
P0749 = Pressure Control Solenoid "A" Intermittent.
It is not a fault with the TCC but I can't find any information on the diagnostics of this trouble code.
Since problem is intermittent, check for loose or contaminated wire connections.
Aug 16, 2010 at 6:31 AM
