2002 Acura MDX Installing front Lower control arm (driver
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
ARTISTIC94555
While removing LCA, I had to place jack under brake rotor and lift it up, then LCA was free to come out.
Now to install new one, it is not possible to lift up by placing jack under rotor as it is free to move horizontally. How to lift up strut so that 3 holes in LCA can be aligned. Compressing the spring alone doesn't work as [img:955d96293c]http://www.2carpros.com/forum/automotive_pictures/207067_IMG_01190_1.jpg[/img:955d96293c]
Jun 27, 2008 at 10:03 AM
MASTERTECHTIM
  • 4,750 POSTS
pry the lower control arm down with a long pry bar.
Jun 27, 2008 at 10:49 AM
