2001 Acura MDX VTM-4 failure
2001 ACURA MDX
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
JERRYMA
I asked the dealership to diagnose a intermittent clunking / rumbling sound that seemed to be coming from the engine compartment. They changed the rear differential fluid but that did not resolve the problem - based on my research this response is pretty typical. The mechanic then informed me that it would cost over $2000 to replace the rear differential and he did not recommend it. His recommendation was based on the fact that continuing to drive the car would not cause more damage / increase the ultimate cost of repair. He also said that the failure mode would not be catastrophic (a breakdown) and that, in fact, I would simply lose the traction control feature. The car would then function as though I had a standard differential. Do you agree with his analysis, forecast, and recommendation? Is the noise likely to worsen or ultimately disappear when the there is a complete failure? There are no other indications of a problem beyond the intermittent noise - the car drives fine and there are no alarms.
May 18, 2010 at 6:20 AM
THIS IS MIKE
  • 686 POSTS
You may want to take it to another dealer or independent repair shop for another opinion. Intermitant noises can be difficult to diagnose, especially if you hear it coming from the front and they are saying it it coming from the rear. Some shops have audio transmitters that can be placed around the vehicle and pick up where noises are being generated from. A good old fashion test drive with a trained technician is usually the best way to know for sure.
May 25, 2010 at 6:55 AM
