high mount break light dosen't work even replace a new blub.
Aug 27, 2010 at 5:11 PM
BLUELIGHTNIN6
✓Experienced Mechanic
are regular brake lights working? check fuses. if good than check for bad ground , should be behind left rear lining. brake light failure sensor (left side of cargo area) may also be bad if all else is tested good.
Aug 28, 2010 at 7:18 AM
