2001 Acura MDX about codes
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
OYESOLA A OSUNGA
my Acura showed these CODES P0108 P01129 P0325 . HOW TO FIX THE PROBLEM.
May 30, 2009 at 9:52 PM
F4I_GUY
  • 3,302 POSTS
P0108....Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0325....Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
Most likely what you will find with these codes, is that you will have to replace the knock sensor and the MAP sensor. It would be wise to check the wiring and connection before hand of replacement though.
Goodluck.
Jun 7, 2009 at 4:29 AM
