P0108....Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0325....Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
Most likely what you will find with these codes, is that you will have to replace the knock sensor and the MAP sensor. It would be wise to check the wiring and connection before hand of replacement though.
Goodluck.
Jun 7, 2009 at 4:29 AM
