1987 acura legend, 2.5 ltr, 4 door sedan, 120,000 miles. Replacing rear brake pads. I dont have a piston compression tool. what else will work.
Nov 3, 2007 at 2:46 PM
A large C-clamp can retract a push-in piston. Rear calipers are often screw-in, so check the piston face for a slot and turn it back in if present.
The owner of a 1987 Acura Legend is replacing rear brake pads and does not have a piston compression tool. The expert says a large C-clamp may work, but rear pistons are often screwed in, so the caliper should be checked for a slot and the piston turned back in if needed.
