1995 Acura Legend when tank is under half.. it's not starti
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
APOST92837
This is the second fuel pump. I replaced the last one about 9 months ago or so. I also had replaced the relays, someone told me to replace the Float (in the gas tank).. What do you think?
thanks
Andrew
Mar 15, 2009 at 3:01 PM
DOCFIXIT
  • 18,828 POSTS
When it won't start do you put fuel in and it runs? if yes how much fuel do you add to get it to read full?
Mar 16, 2009 at 6:02 AM
APOST92837
it was at half, and I filled it up additional 9.2 gallons before it was full. Also note that my car tilts down from the back( i need springs or shocks).. maybe the tank is tilted and fuel doens't go to the pump?..
thanks
Mar 18, 2009 at 3:39 AM
DOCFIXIT
  • 18,828 POSTS
Are you useing Honda pumps or part house
Mar 18, 2009 at 8:59 AM
DOCFIXIT
  • 18,828 POSTS
Tank capacity is 13.2 gal so 9.2 leaves 4 gal. or 1/4 of tank not half as gague indicates. suspect pick up and or pump assembly mount to high in tank.
Mar 19, 2009 at 2:01 AM
