1995 Acura Legend i pulled my radiator overflow and found o
1995 ACURA LEGEND
DRAYKO321
Engine Performance problem
1995 Acura Legend
i am losing alot of power most of my buddies tell me blown head gasket but i dont just want to jump into that i just drove it round trip 200 miles in the heat with the ac on just real sluggish up hills and getting up to speed thanx
Aug 2, 2009 at 3:11 PM
  • 31,937 POSTS
Hi there,
If you are not loosing coolant or over heating, start with a full tune including all the filters.
mark (mhpautos)
Aug 2, 2009 at 3:16 PM
DRAYKO321
what does a full tune entail change oil and filter plugs what are all the filters i just replaced fuel filter other day thank you for responding so quick have a nice day
Aug 2, 2009 at 3:22 PM
  • 31,937 POSTS
Hi there,
Plugs, leads, fuel you have done, air, do a comp test, check fuel pressure and flow, check the ECU for fault codes. ignition timing, and a run on an oscilloscope if you can as this will give a full ignition break down.
mark (mhpautos)
Aug 2, 2009 at 3:29 PM
DRAYKO321
thank you i will get back to you as soon as i get this done do you think it could be head gasket and is it okay to continue to drive
Aug 2, 2009 at 3:33 PM
  • 31,937 POSTS
Hi there,
Normally with a head gasket problem you will have chronic miss fire, overheating, coolant loss and often emulsified oil, that is coolant & oil mixing together causing it to go very thick and coffee coloured, if this is not the case do the simple things first, tune and see how you get on.
mark (mhpautos)
Aug 2, 2009 at 3:42 PM
