1995 Acura Legend heater blower
1995 ACURA LEGEND
132,000 MILES • 6 CYL • FWD • AUTOMATIC
XANDERSDAD08
The message below is a reply i got from you guys today, thank you for your speedy response and i will give this a shot but i do need to know what the PW means that you referred to in the last sentence? thank you guys again for all of your help!!
Hi
Was old motor faulty? if no then Power Transistor in not providing ground mounted on blower unit. Check black wire on PT see if ground is present if not check behind right kick panel ground . If good the PW faulty
Thanks for donate
Aug 21, 2010 at 9:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
I believe that was a typo and was meant to say PT which is Power Transistor.
Aug 21, 2010 at 10:34 AM
