1995 Acura Legend front passenger power window
158,000 MILES • 6 CYL • FWD • AUTOMATIC
IANC
passenger window won't operate from master switch
or with its own individual switch
change master switch- did not work
change individual switch- still don't work
all other window work fine from master and individual switches
after pullling off door panel and playing around
with the wirings i discovered that appyling a gound to
to the blue wire in the harnes the window would move up and down
that as far i could take it
where do i go from here
help !
Feb 23, 2009 at 1:14 PM
TED-E-DEE
  • 109 POSTS
Ck. fuses if you have not already. Get a wiring diagram & prform continuity tests & voltage tests on the switches for that motor.
Apr 27, 2009 at 8:37 PM
