1995 Acura Legend blower motor quit
158,000 MILES • 6 CYL • FWD • AUTOMATIC
XANDERSDAD08
I have a 1995 Acura Legend and the blower motor has been cutting off at times and then starting back up, usually it starts back right away. But it quit last night and this time it hasnt started back, and it is very hot here in south alabama. if you could explain in detail what i need to check it would be very helpfull. Thank you
Aug 14, 2010 at 7:35 AM
  • 75,988 POSTS
Hi xandersdad08@yahoo.com, Welcome to 2carpros and TY for the donation
Direct battery power to the blower motor blue and red wire and see if comes on if not check the ground wire if okay-replace the blower motor, if it comes on test the blower motor relay if okay problem is coming from the climate control unit
Aug 14, 2010 at 8:24 AM
