Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
Legend
Engine
Timing Belt
Replace/Remove
i need guide to install timing belt?
1994 ACURA LEGEND
12,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTINJOSEPH2009
MEMBER
1 POST
Aug 8, 2009 at 3:05 PM
CARLIFE65
Experienced Mechanic
i,m sending you this D. this will help you to install belt. and make sure and check that the crankshaft and camshaft pulleys are at TDC.
Oct 19, 2009 at 3:05 AM
Here are the timing belt marks for eh v6 engine. Check out the images (below). Let us know if you need anything else.
Images (Click to enlarge)
Aug 20, 2024 at 8:48 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine overheating
Engine won't start
