1994 Acura Legend Power Antenna
230,000 MILES • 6 CYL • FWD • AUTOMATIC
GIBCOR
Hello I have an antenna that will not go all the way down when the car is turned off and will not extend all the way out when the car is turned on. Is there anything I can do about this?
Mar 11, 2010 at 12:30 AM
KHLOW2008
  • 41,812 POSTS
Hi gibcor,
Check if the antenna is bent and carefully straighten it if it is.
With antenna extended, spray some WD 40 onto the antenna and use a rag to wipe off any dirt that may have accumulated and retest.
Mar 24, 2010 at 11:31 PM
