1994 Acura Legend Overheating
MRS.WALKER420
  • 1994 ACURA LEGEND
  • 6 CYL
  • FWD
  • MANUAL
  • 185,966 MILES
I just got my car out of the shop after it was in there for over a month and 1800$ later, it is still overheating, the car has a new water pump, timing belt, thermostat, all new hoses new spark plugs, new fuel filter, air filter, tune up. New radiator cap. It still overheats I don't know what is wrong with my car please help.
Wednesday, July 29th, 2009 AT 6:05 PM
Try replacing the thermostat for a start that don't work come on back
Wednesday, July 29th, 2009 AT 6:08 PM
MRS.WALKER420
I have already changed the theromostat, do you think the new one is bad.
Wednesday, July 29th, 2009 AT 6:14 PM
Dunno what it went in the shop for but something fishy here.
Get it block and pressure tested to find out what's happening
Wednesday, July 29th, 2009 AT 8:03 PM
MRS.WALKER420
The mechanic said he already pressure tested it and I think he is full of it. I know that today when it started to overheat after I turned the car off I popped the hood and the radiator hose that is on top from the thermostat to the radiotor was hot, so I know that the thermostat is opening up but it looked like it was going to explode it was swollen, and that is a brand new hose. The mechanic said that it meant that it still had a strong pressure. I dont think he knows what is going on.
Wednesday, July 29th, 2009 AT 10:35 PM
If the radiator is not clogged up could be airlock in the system try bleeding it and see what happens
Wednesday, July 29th, 2009 AT 11:59 PM
