1994 Acura Legend cv joints
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
CURIOUSONE
Does anyone know if it is difficult to change the cv joints on a 1994 acura legend? Do you need any special kinds of tools to do so?
Dec 24, 2007 at 8:34 PM
MERLIN2021
  • 17,250 POSTS
You'll need a socket large enough to remove the axle nut, and a tool to break the ball joint free. Then just pull the strut rotor and all outward until the cv-joint clears the knuckle, I would change the whole shaft, Reanufactured axles are pretty cheap, and it's quicker and easier than messing with seperating the old joint! Use a bucket under the inner joint to catch any tranny fluid that might leak out!
Dec 24, 2007 at 11:02 PM
