HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Acura
Legend
Engine
Air Filter
Replace/Remove
SPONSORED LINKS
1994 Acura Legend
FLOYD C. GRAY
MEMBER
1994 ACURA LEGEND
6 CYL
2WD
AUTOMATIC
163,000 MILES
WHATS THE PROBLEM WHEN OIL COMES THROUGH THE AIR FILTER? THE PCV WAS CHANGED AND THE PROBLEM STILL PERSIST.
Monday, April 14th, 2008 AT 11:54 AM
THEBIGGMCDOG
MEMBER
MAKE SURE YOU'RE PCV VALVE IS WORKING PROPERLY, MAKE SURE THEIR IS AIR.
SPONSORED LINKS
Monday, May 26th, 2008 AT 12:54 PM
KHLOW2008
MECHANIC
Most probably the blowby is a bit high, always happens to aged engines.
Monday, May 26th, 2008 AT 2:59 PM
Please
login
or
register
to post a reply.
Related Air Filter Replace/Remove Content
1994 Acura Legend Labelled Small Hoses/tubes
There Are Numerous Tubes From Mostly Around The Intake Manifold On The Left. These Tubes I Think May Be Vacuum Tubes. They Have Specific...
Asked by
danielsw
1 ANSWER
1994
ACURA LEGEND
GUIDE
Air Filter Replacement
Changing the air filter for your car is easy to do and will save you money as well as help your engine last longer. This filter removes contamination from the air the engine...
1994 Acura Legend
Just Had Engine Replaced, We Put The Transmission Back In Fine But When Putting The Car In Gear The Wheels Will Not Turn Help Please
Asked by
acura94
1 ANSWER
1994
ACURA LEGEND
1991 Acura Legend Timing Belt
If Timing Belt Is Broken On This Vehicle, At About 2500 Rpms Is The Engine Repairable? Is This Significant Damage? How Much Is A Timing...
Asked by
2586jp
1 ANSWER
1991
ACURA LEGEND
Timing Belts
How Do I Find Timing Marks On A 1989 Acura Legend?
Asked by
jayn
1 IMAGE
1989
ACURA LEGEND
Should I Replace The Engine In My 1991 Acura?
150000 Miles 1991 Acura Legend V.6 Engine The Car Has Had Excellent Maintenance Before We Owned It. It Has Had Heating Problems For The...
Asked by
bubblesbaronian
1991
ACURA LEGEND
VIEW MORE
SPONSORED LINKS
Fix an Engine with Low Power!
Air Intake Boot Replacement
Symptoms of Low Engine Power
Online car repair manuals
