1993 Acura Legend won't crank
1993 ACURA LEGEND
87,000 MILES • 4 CYL • FWD • MANUAL
DMCCORRI
lights,strong,batt.voltage high,tapped on the starter while ign.in start position
Feb 29, 2008 at 9:14 PM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then test at the clutch switch under the dash on the pedal assembly.Should be power on one side, then the other when clutch pushed in
Feb 29, 2008 at 11:15 PM
