1993 Acura Legend tranny
177,000 MILES • 6 CYL • FWD • AUTOMATIC
ONELOVE973
HAD A TRANS PUT IN MY LEGEND BUT WHEN DRIVEN IT WILL NOT SWITCH TO SECOND GEAR RPM'S R HIGH WHEN AN IF IT DOES SWITCH...ARE THERE ANY DIAGNOSES OR ISSUES THAT COULD B CAUSING THIS OR IS TRANNY JUS A BAD TRANS BOUGHT PERSO WHO SOLD ME TRANS SAIDS IT CAME OUT OF RUNNING CAR...AN I SHOULD CHECK FURTHER B4 CHANGING ALSO GEAR SHIFT WOT ENGAGE UNLESS I PUT KEY IN SHIFTER AN PUT IN NEUTRAL THEN START AN GO I DONT HERE THE CLICK I USED TO HEAR WHEN STEPN ON BRAKE THANKS FOR ALL YA HELP...
Jun 27, 2010 at 12:22 AM
  • 31,937 POSTS
Hi there,
If this was a re built transmission i would be taking it back to the business that did the work, if not get a trans specialist to do a test and report on this problem, they can do a scan to test for electrical errors.
mark (mhpautos)
Jun 27, 2010 at 12:34 AM
