1993 Acura Legend sluggish when accelerating
JAHFLITE
  • 1993 ACURA LEGEND
  • 6 CYL
  • 261,000 MILES
I would to know what cause my car to move sluggish on the take off.
Thursday, July 15th, 2010 AT 6:30 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Friday, July 16th, 2010 AT 1:15 AM
