1993 Acura Legend Running Hot
1993 ACURA LEGEND
182,000 MILES • 6 CYL • FWD • AUTOMATIC
RLJONES1US20
The temp guage goes up at 70+ mph and also in stop and go traffic. The overflow container fills with coolant fron the radiator. The heat does not work until the temp guage falls back to normal. Can you help me?
I replaced the thermostat and radiator cap but still does the same thing.
Jan 19, 2008 at 4:26 AM
MASTERTECHTIM
  • 4,750 POSTS
remove the actual radiator cap and check coolant level there. sounds like low on coolant. let us know how it is.
Jan 19, 2008 at 4:32 AM
ALBOOGY
YOU MIGHT WANT TO CHECK IF FAN IS KICKING ON HAD THE SAME PROBLEM. FAN WOULD WORK INTERMIDDENT I HAD TO REPLACE FAN MOTOR
Jan 30, 2008 at 1:42 PM
