Hi mstamik,
For an engine to run hot, there are many possibilities :
1. Faulty thermostat.
2. Cooling fans not working or weak
3. Radiator or water passages clogged.
4. Bad head gasket.
5. Insufficient coolant, might be due to leaking or a bad head gasket
6. Faulty water pump.
You need to verify what is causing it by doing tests and visual inspections.
SPONSORED LINKS
Monday, February 2nd, 2009 AT 9:52 AM
