1993 Acura Legend REV Question
RIFFLELPN
Engine Performance problem
1993 Acura Legend 6 cyl Front Wheel Drive Automatic
The car starts and runs good but won't rev over 4000rpm. Acts like it's governed there.
Aug 11, 2009 at 12:09 PM
KHLOW2008
  • 41,812 POSTS
Hi Rifflelpn,
Is the Check engine light showing?
Was any repairs done prior to this happening?
Aug 15, 2009 at 1:26 AM
RIFFLELPN
No check engine light is on. I don't know much about the car because I bought from a tow yard as am impound. I have checked for plugged exhuast and checked the fuel pressure. They are both fine. It's such a wierd symtom that I'm at a loss. Thanks.
Aug 17, 2009 at 10:16 AM
KHLOW2008
  • 41,812 POSTS
Symptoms described could be caused by a faulty/out of adjustment TPS or ECM so these are the 2 items next on your list.
When engine stopped revving at 4000 rpm, it just stays or is it hunting as if the engine is starving of fuel?
Aug 17, 2009 at 11:43 AM
RIFFLELPN
The engine just cuts out like it hit a rev limiter. It will start again at about 3700, run up to 4000 and repeat.
Aug 26, 2009 at 12:32 PM
KHLOW2008
  • 41,812 POSTS
Have you confirmed that the CEL shows at ignition ON and goes off after 2 seconds and does not come on while driving?
Aug 27, 2009 at 3:14 AM
RIFFLELPN
Yes. The check engine comes on normally at start-up. I have now replaced the TPS and the ECU.
Oct 28, 2009 at 6:37 AM
KHLOW2008
  • 41,812 POSTS
Is the problem still there an exactly the same?
When replacing the TPS, was it calibrated?
Oct 29, 2009 at 5:26 AM
