1993 Acura Legend OIL LEAKS INTO SPARK PLUGS
190,000 MILES • 6 CYL • FWD • AUTOMATIC
ZACDELROCHE
My spark plugs are covered in oil and the exhaust starts smoking white after the car warms up. It started periodically and now it is doing it all the time. If I rev the engine up it smokes less. My car is a '93 legend 3.2. What can i do to prevent this from getting worse. BTW theres no oil n coolant vise versa????
Nov 6, 2010 at 7:40 AM
KHLOW2008
  • 41,812 POSTS
Hi zacdelroche,
There are 2 separate problems here.
1. Oil in plug seal. There is a leak in the plug seals under the valve cover and/or O rings under the rocker carriers. This would result in oil getting to the spark plugs. The seals and/or O rings have to be replaced to rectify.
2. Oil is getting into the cylinders and the most common areas would be via the valve seals. Standard procedure is to remove the heads to to perform a valve job to solve the problem.
Nov 6, 2010 at 8:24 AM
