1993 Acura Legend
JUSTIN HAIGHT
Brakes problem
1993 Acura Legend 6 cyl Front Wheel Drive
HOW TO REPLACE DISC'S GRINDING NOW
ALSO WHERE IS THE SINGLE FLASHER ??
Jun 19, 2008 at 1:23 AM
KHLOW2008
  • 41,812 POSTS
Hi JUSTIN HAIGHT,
To replace the front disc pads you need to remove the lower slider bolt attaching bolt.
Swing caliper assy upwards and you can get the pads out.
Push caliper piston back into the caliper and you can reinstall the pads and calipers.
Ensure slider bolts are moving freely before reinstalling. Lubricate if necessary, DO NOT use oil based grease.
Single flasher? You mean the turn signal relay?
It is plugged into the fusebox under dash on driver side.
Jun 19, 2008 at 1:33 AM
