1993 Acura Legend
MR.GREEN!!!
  • 8 POSTS
1993 Acura Legend 6 cyl Automatic
when doing a tune-up do i change the coil packs and wires? and what else do i need to do for a good tune- up?
Aug 27, 2008 at 10:18 AM
  • 31,937 POSTS
Hi there,
Under normal conditions the coil pack do not need changing, you can replace the leads, spark plugs, air & fuel filter, clean the throttle body, re set the valve clearances (if manual tappets) & check the ignition timing, (if applicable)
Mark (mhpautos)
Aug 27, 2008 at 10:50 PM
MR.GREEN!!!
  • 8 POSTS
What are the leads?
Aug 28, 2008 at 10:53 AM
  • 31,937 POSTS
Hi there,
Spark plug hi tension leads, or what you call the wires i believe.
Mark (mhpautos)
Aug 28, 2008 at 10:58 AM
MR.GREEN!!!
  • 8 POSTS
so how do i remove the coil packs to change the leads and plugs? also, the fuel filter where is it and how do i replace it?
Aug 28, 2008 at 2:45 PM
KHLOW2008
  • 41,812 POSTS
Hi MR.GREEN!!!,
Your model is Distributorless Ignition System so the coil packs are directly installed over the plugs, no leads to be replaced.
The fuel filter it located on the Driver side firewall in engine compartment.
Aug 28, 2008 at 11:35 PM
MR.GREEN!!!
  • 8 POSTS
so how hard is it to remove the coil packs and change the plugs? how do i do it? also. the fuel filter how do i remove and replace?
Aug 29, 2008 at 10:40 AM
  • 31,937 POSTS
Hi there,
The cop (coil over plug ) ignition system will normally have 1 attach point per coil and when un done they will lift off, you may have to undo the wire plug to move them, as for the fuel filter i will try to locate a pic of it's location and post it,i feel that you would benefit from purchasing a work shop manual as all this info with good pics will then be at your fingertips.
mark (mhpautos)
Aug 29, 2008 at 3:06 PM
