1993 Acura Legend
1993 ACURA LEGEND
AJ06
1993 Acura Legend
where do I find the spark plug?
Apr 19, 2008 at 7:59 AM
BRUCE HUNT
  • 3,754 POSTS
When you open the hood you should see a part that has heavy black wires running to it and plugging in forming a circle. This is the distributor. Follow the wires to the other end and you will find the plugs. Use caution not to harm the wires as you remove the connector from the plug.
Apr 19, 2008 at 3:30 PM
THEBIGGMCDOG
  • 25 POSTS
it is found in the coi; pack it has 2 bolts, remove the 2 bolts and raise it and there u will find the spark plugs.
May 25, 2008 at 5:48 PM
THEBIGGMCDOG
  • 25 POSTS
[quote:e3eb289b5e="aj06"]1993 Acura Legend
where do I find the spark plug?[/quote:e3eb289b5e]
