1992 Acura Legend Vehicle Speed Sensor
263,000 MILES • 6 CYL • FWD • AUTOMATIC
LIVEWIRE5
I changed the VSS last year with a used one. It worked fine for about 3 days, went haywire and then quit. This week I put another VSS in my car (that was working fine in a 1991 Legend) and the same thing happened again. It worked fine for a day, went haywire and then quit. What's going on?
Thanks.
Jun 16, 2009 at 1:27 AM
KHLOW2008
  • 41,812 POSTS
Hi livewire5,
Either you are the lucky one, both VSS failed when installed to your vehicle or the wiring circuit is bad. Check if the connectors are contaminated or loose.
Jun 24, 2009 at 3:26 AM
