1992 Acura Legend Power steering fluid leakage
240,000 MILES • 6 CYL • FWD • AUTOMATIC
MUYIYA007
I have a leak from my Rack and Pinion assembly. I want to repair it with a Rack and Pinion seal kit due to the cost of the entire Rack and Pinion assembly which is $500+.
Will this fix the problem if the repairs are done correctly?
Do you have to use Honda brand power steering fluid instead of conventional to not allow this to happen again?
Jan 25, 2009 at 5:30 AM
ZACKMAN
  • 4,202 POSTS
If the leak is coming from a seal in the R/P, then yes. But if the unit is cracked thus letting fluid out, then no.
You should always use Honda P/S fluid in this vehicle.
Jan 27, 2009 at 2:44 PM
