i need to know where my turn signal fuse?
1992 ACURA LEGEND
266,000 MILES • 6 CYL • 2WD • AUTOMATIC
OLSEN85
i have the same problem as the 91 acura with my fuse box but mine is not the same as his. i need to know where my turn signal fuse is but have know idea. chris
Mar 28, 2010 at 4:22 PM
  • 110,244 POSTS
The fuse you are looking for is fuse 13. It's located in the fuse box under the dash on the left side.
When you check a fuse, it is important to both check the fuse condition and if power is present to and from the fuse. A fuse can check good, but have no power being supplied to it.
Here is a link that explains how to perform the test:
If you look below, I provided the wiring schematic indicating both the fuse for the signals and the hazard lights. Again, both will be in the fuse box under the left side of the dash.
I hope this helps. Let me know if you have other questions.
See pic below.
Dec 9, 2021 at 12:02 PM
