1992 Acura Legend Instrument Panel Problems
215,005 MILES • 4 CYL • 2WD • AUTOMATIC
XMAN3000
My Speedometer needle keeps fluctuating while I drive, then it goes to zero. Then sometimes it works fine then kicks out again. What could be my problem? It alos affects the milege counter and the trip meter as well!
Jan 12, 2010 at 7:03 AM
KHLOW2008
  • 41,812 POSTS
Hi xman3000,
The Vehicle Speed Sensor located on top of the differential axle is bad causing the erratic speedometer and odometer readings.
Jan 13, 2010 at 12:39 AM
