1992 Acura Legend I cant see how fast IM going!!!
ANDI12
Electrical problem
1992 Acura Legend Front Wheel Drive Automatic 135xxx miles
Sometimes my speedometer goes crazy, Example- up to 100 and im only going 40 or sometimes its zero
Is this Even a Electrical Problem????
Nov 19, 2008 at 5:25 AM
DAVE H
  • 13,383 POSTS
speed sensor
Legend
Verify fuse No. 22 in underdash fuse block is okay. Speed sensor is located next to oil filter. Unplug 3-pin connector from speed sensor.
Using an ohmmeter, check for continuity between Green/White wire and ground. See Fig. 4 . If continuity exists, go to next step. If continuity does not exist, repair open between speed sensor and ECU ground. ECU ground is located next to throttle body.
Fig. 4: Testing Vehicle Speed Sensor (Legend)
Courtesy of AMERICAN HONDA MOTOR CO., INC.
With ignition on, measure voltage between Black/Yellow wire and ground. If battery voltage is present, go to next step. If battery voltage is not present, repair open in Black/Yellow wire between speed sensor and underdash fuse box.
Measure voltage between Yellow/Red wire and ground. If voltage is about 5 volts, go to next step. If voltage is not about 5 volts, repair short to ground in Yellow/Red wire.
Reconnect wiring to speed sensor. Raise and support vehicle. Connect voltmeter between sensor connector Yellow/Red wire and ground. With ignition on and transaxle in Neutral, block one front wheel and slowly rotate other front wheel. Voltage should pulse between zero and 5 volts. If voltage does not pulse between zero and 5 volts, replace speed sensor.
Nov 22, 2008 at 10:27 AM
