1992 Acura Legend Check Engine Light Codes
1992 ACURA LEGEND
185,000 MILES • 6 CYL • FWD • AUTOMATIC
AARON JOLLEY
My check engine light code goes like this: 5 flashes, a long pause, one sustained flash followed by 2 flashes, another long pause, and then 6 flashes.
Can you tell me what this means, please?
Jun 4, 2010 at 9:49 AM
KHLOW2008
  • 41,814 POSTS
Hi Aaron Jolley,
Code 5 = MAP sensor. Check for dislodged hoses.
Code 12= EGR System. Could bea faulty EGR, clogging of passages or due to fault with the MAP sensor.
Code 16 = Fuel Injector circuit.
Jun 5, 2010 at 2:34 AM
DAISYMAE
  • 9 POSTS
I have an acura legend and im trying to run the self diagnosis test with jumper wires. I dont know where to look for the flashes after i hook up jumper wire. Is it the check engine light?
Jul 27, 2011 at 5:33 AM
KHLOW2008
  • 41,814 POSTS
Yes, the Check Engine Light would flash the trouble codes.
Jul 27, 2011 at 5:05 PM
