1992 Acura Legend Car won't crank in cold weather
95,000 MILES • 6 CYL • 2WD • MANUAL
MARLENE YORK
This is my second winter with this car.Last winter I took it to the mechanic shop and they had no idea what to do to fix the problem. I had to bum a ride to school, but upon my arrival in the heat of the day, the legend would crank right up.I have moved and now have the car under a garage and now it is cold again and the problem is repeating itself. Please advise me. Thanks in advance for your help.
Nov 16, 2008 at 6:22 AM
ZACKMAN
  • 4,202 POSTS
I'll give you two areas to check. They they come up good, then we'll troubleshoot some more.
1. Check your coolant temp sensor circuit.
2. Check intake air temp sensor circuit.
Nov 16, 2008 at 3:20 PM
