1992 Acura Legend brake lights!
18,500 MILES • 6 CYL • 2WD • AUTOMATIC
KAZZIMARA
I went to get a brake tag for my car the other day and the lady told me that my back brake lights were not working! I changed the bulbs out, looked at all my fuses, and swapped out the break switch and they are still not working! The only thing that I can think of that maybe be it is the only non labeled fuse in my car which just says SMALL RELAY! I don't know what do to because you please help? sincerely Jennifer
Mar 31, 2010 at 7:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you can't always see a faulty fuse, you need to actually test them with a meter.. if the fuses and switch are good though then the only thing on the circuit would be the signal switch that may be faulty.
Mar 31, 2010 at 7:50 AM
