1992 Acura Legend
128,000 MILES • 6 CYL • FWD • AUTOMATIC
JDMLEGEND92
My power steering fluid stay going low like at least 3 or 4 days
The steering wheel does not goin stiff or get not hard when turning.. I dont see no drops on the floor.. I would like to know what is the problem??
My second question is when i install the speed senor course on the D4 blinding my performace in acc. as been lil weak... Would like to know if that have any thing to do with it? But when i try to put it in D1 it wouldnt let me it go from D2-D4 only it look like it its lock.. Can any help me out? thankx
Dec 29, 2009 at 12:54 AM
KHLOW2008
  • 41,812 POSTS
Hi JdMLegend92,
For the power steering fluid to go down there definitely must be a leak somewhere. If it is not getting to the floor, then you need to check the differential gear oil level. Any leakage of the power steering fluid at the speed sensor geat can get into the differential and increase the level.
As to the second part, I am not sure what you are trying to explain.
Can you try to rephrase it or explain in more details?
Dec 29, 2009 at 6:31 AM
