1991 Acura Legend differential
134,000 MILES • 6 CYL • FWD • AUTOMATIC
LEGEND1991
I have a 91 acura legend and I am replacing the differential. I am having a problem with connecting the transmission extension shaft to the diff. everything is lined up and the diff is hung and half in but I can't get the shaft to slide over the lock ring. any suggestion on this would be helpful. thanks.
I have tried putting a bolt in the end of the shaft and tapping it in but I am also affraid to hit it too hard, I don't know if it will effect the shaft or the diff. gears.
mileage of the engine is 83k but my dash reads 134k never had it turned back
Mar 31, 2008 at 4:47 AM
THEBIGGMCDOG
  • 25 POSTS
turn both shafts and it will slide in
May 26, 2008 at 6:14 AM
