1991 Acura Legend
121,000 MILES • 6 CYL • 2WD • AUTOMATIC
RREPIQUE
My air conditioner and heater do not put work. The system runs with fan and temp comtrol but does not produce heat nor air. Thanks Ron
Apr 7, 2008 at 12:06 PM
BRUCE HUNT
  • 3,754 POSTS
off hand i would venture a suggestion to check the damper control on the plenum for the system. you may have a cable that is broken, etc. i would guess that the systems, heat and ac, work but they are not able to move the air out to the inside of the vehicle.
Apr 8, 2008 at 1:29 AM
