My air conditioner and heater do not put work. The system runs with fan and temp comtrol but does not produce heat nor air. Thanks Ron
Apr 7, 2008 at 7:06 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
BRUCE HUNT
CAR REPAIR CONTRIBUTOR
off hand i would venture a suggestion to check the damper control on the plenum for the system. you may have a cable that is broken, etc. i would guess that the systems, heat and ac, work but they are not able to move the air out to the inside of the vehicle.
