1990 Acura Legend Replacing Brake Light Sensor
1990 ACURA LEGEND
WESTLEYASHLEY
1990 Acura Legend
Brakes remain on after the car is turned off and then drain the battery. The sensor pedal is making contact with the sensor, so I assume the sensor needs to be replaced. How do I get the brake light sensor off in order to replace it?
Aug 31, 2009 at 4:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely your stoplight switch just needs adjusted, not replaced. try this first...
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_895.jpg
Aug 31, 2009 at 4:14 PM
