HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Acura
Legend
Engine
Symptoms
Overheat
1990 Acura Legend OVER HEATING
ACURA1905
MEMBER
1990 ACURA LEGEND
6 CYL
FWD
AUTOMATIC
336,225 MILES
I HAVE A 1990 ACURA LEGEND V6L AND NEED LOCATION OF THERMOSTAT TO REPLACE IT? THE CAR IS OVERHEATING WHAT DO I DO?
Tuesday, July 8th, 2008 AT 2:51 AM
KHLOW2008
MECHANIC
Hi acura1905,
Thermostat is located inside the housing connecting the lower radiator hose to the engine.
When engine overheats,
1. Check if there is enough coolant in the radiator system.
2. Check if the fans are working.
Thermostats seldom gives way out of the blue, usually only happens after any overheating had occurred.
SPONSORED LINKS
Friday, July 11th, 2008 AT 10:28 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1990 Acura Legend Coolant Boils Over.
I've Recently Noticed That My Coolant Level Is Dropping And After Periods Of Driving, The Coolant Boils Out Of And Overflows The Overflow...
Asked by
skinart15
1 ANSWER
1990
ACURA LEGEND
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1994 Acura Legend Car Overheating
Engine Was Running Hot So I Got A New Radiator, Temp Sensor, And Thermostat. Drove Away From Repair Shop And 5 Mins Later, Car Starts...
Asked by
dunson-b
1994
ACURA LEGEND
My 1994 Acrua Legend Is Overheating! =(
I Have A 1994 Acura Legend. Recently It Has Been Overheating And Is Apparently Low On Fluid. I Had An Engine Swap Done At The Dealership 50k...
Asked by
domjansson
1994
ACURA LEGEND
Engine Overheating
I Have A 1994 Cadillac Deville. 138.000 Miles, 4.9 Liter. I Have A New Water Pump And New Radiator. After The New Radiator Was Installed...
Asked by
tonyzump
ACURA LEGEND
1994 Acura Legend Car Overheats, And Leaks W/ New...
Hi, I Purchased A 94 Acura And It Runs Good, Has A New Radiator And Overheats And Leaks Really Bad. I Had A Mechanic Look At It And The...
Asked by
webcar
1 ANSWER
1994
ACURA LEGEND
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test For Leaks
Online car repair manuals
