Ignition control module and coil?
1990 ACURA LEGEND
230,000 MILES • 6 CYL • FWD • AUTOMATIC
ARTSKIN76
What would be the symtoms of a faulty ignition coil and ignition control module? I'm getting very poor gas mileage, engine miss as well as rough engine vibrations..I recently did a full tune up so I know the wires, plugs, distributor cap and button are new...
Thanks for your time
Apr 7, 2008 at 9:59 PM
BRUCE HUNT
  • CAR REPAIR CONTRIBUTOR
  • 3,754 POSTS
in general, when the two items you mention go bad, the vehicle will not run.
here are some thoughts. First off, was the car having the problems prior to the tune-up? If so, then I might look at the injectors, and when the plugs were pulled out of the vehicle what did they look like. Sometimes one will have a color that varies from the others which can help to narrow down.
has the vehicle had a compression check done? Have you looked the pcv valve and egr valve?
Apr 8, 2008 at 12:27 PM
BRIAN MULLIGAN
Hey artskin76 we lost contact and I've been trying to find you again if you could reach out to me sometime?
Apr 17, 2024 at 6:05 AM
