1990 Acura Legend ECU Scanner?
220,000 MILES • 6 CYL • FWD • AUTOMATIC
RICKEROSS
Which diagnostic scanner do I need for my car and where is the connection? I know the ECU is located under the passenger seat but are unable to find out which OBD is needed..Thanks so much for any help you can give me on this..
Jan 9, 2008 at 5:58 PM
  • 75,988 POSTS
Yours is an OBD1 system-get a repair manual it should be in there how to extract the code/s could be using a jumper wire or the key method.
Jan 9, 2008 at 6:30 PM
