1990 Acura Legend 1990 Acura Legend Engine Coolant Leak
SHANEW
Engine Cooling problem
1990 Acura Legend 6 cyl Front Wheel Drive Automatic
So, my engine is leaking coolant from the back of the engine, its a very fast leak and drains my coolant in a matter of minutes when the car is both on and off. What are the possible areas that it could be leaking from, and what ways could they be fixed? thank you.
Oct 10, 2010 at 10:06 AM
KHLOW2008
  • 41,812 POSTS
Hi shanew,
Most likely the heater hoses are the culprit. Checks and test have to be carried to determine the cause and required action.
Oct 16, 2010 at 12:44 AM
